My 250r stator went out on my bike I got a new one comin but I've talked to a few people and they said when stator goes it takes cdi with it is that true my parts won't be in til Tuesday so I kinda want to figure it out before the new comes in
Not true at all. I have seen one?? bad CDI on a TRX. Stator will prolly have you screamin again! Let us know!
O its u how's it goin yea a couple of people told me I'm not sure I don't have a trike but all the other web sites suck the quad one on here sucks this is the only forum that I can get info that helps case any one wants to coment on me posting on here that's y
trx250r.net is a good place for information theres alot of hopped up machines on there and alot of talking about problems and upgrades.
]1986 ATC 330R
On there to not that great
The CDI's will fail, but it is not to common for them to fail with a stator.
Usually if that condition happens where both failed, it would be because of a short of some sort, or messing with adding the wrong lighting system. I did see one case where LED's were added to a quad and took out the stator and CDI.
The 85 CDI's are there own animal on the trike, with a single round plug. If that is bad, make sure you get a 85 CDI. No others will work unless you update to a 86 wire harness, then you can swap the quad stuff all day long. All The 250R stators are all swappable though.
Did you just loose all spark, or is the bike not reving right?
Proudly NOT a member of
"Team on the Teat"
Well once again I don't have a trike its a 87 250r. And I'm being told they r common so I'm asking
Drjoe171 u post on almost ever forum I start lol but thanks for info
awwww it's over 90 degrees outside and I got NOthin' better to do.
Gotta keep my triker friends safe and happy.
Plus, doing this keeps me from feeling guilty about doing 'nothing'.
If I go outside, there are 100 things that will scream at me for attention.
125 m need it's gearbox torn down, gotta go look at another one for parts
and some 20 ga shells to reload LIGHT for a side by side.
so here I am, getting away with nothing, again.
Good luck man.
Well thanks man need to get some pics of my bike up here
