Results 1 to 15 of 18
Thread: Big red 250es engine noise vid posted
    Holyrood Newfoundland
    114
    i have a 1985 bigred250es and it has a knock coming from the bottom end on the right side cover i did the screwdriver test and heard it loudest right in the middle of the case under the honda logo but it could be heard throught the motor just quieter id dosent go away when riding im not sure what is making the noise
    http://www.youtube.com/watch?v=Tu_IBQ2qRio
    Jan 2011
    mifflinburg
    525
    Check the oil level. try to readjust your Cam Chain. Maybe thats it
    114
    oil was just changed and chain was tightend i think its a bearing but dont know
    Jun 2009
    Tunkhannock,Pa
    904
    could be rod bearing or crank bearings
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Sarnia, Ontario, Canada
    3,415
    Cam chain is auto adjustable..remove the hydralic adjuster on the front of the engine and check it as per the manual you can find on the site.
    Start with the simple..but it doesn't sound simple. Sounds f*&^ed..how did this happen?
    I got an brand new (NOS) engine in case it doesn't work out for you..PM me if interested.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    114
    yah im pretty sure the crank bearings are toast it just kinda developed over time but now its bad
    Pacific NW
    4,255
    Quote Originally Posted by matt22895 View Post
    I had a 250es knock that I would have bet 100$ was a rod knock.
    Made me sick from 40 yards.
    Took a breath and counted exhaust pulses.
    They coincided perfectly with the knock timing.
    Figured it was in time with valve noise.
    Adjusted the valves and it was gone.
    Hope yours is a super easy fix.
    This computer doesn't want to play audio for some reason
    but sure sounds like a good idea to post 'funny' noises.
    NEPA
    7,051
    When I read this,I simply assumed rod. But I can't discern Anything from that video. Set your valves,and then if it is still there. It will be your timing chain is worn out ,or a rod kit.
    Dec 2010
    S.E. Illinois
    1,178
    i don't have a Big Red, but that's almost how my 125 is sounding. basicly from the same spot your discribing too. i'll be finding out what it is on mine before too long, when i get the case repaired. i've heard it could be anything from a wrist pin to a spun crank bearing. guy who gave me the quote on fixing my case wouldn't give me a quote for it (it had been stolen and damage occured), because there was no way for him to know exactly what might be wrong with out taking it apart and he wasn't about to work on it till he knows he is getting paid for his work.
    here's mine for referance if your wondering.
    http://youtu.be/Zk2o24XRqfs
    74 HONDA ATC 70
    3,415
    The other side of this is..doesn't really matter what the individual part is that failed!!
    But why? You aren't just going to open it and replace one part..you are gonna rebuild it completely. The 'why' part will tell you how much other collateral damage there is..
    If it was run oil of oil or the oil was water contaminated..it total over haul. If it's just an incidental bearing spin(unlikely) then you might get away with just lower end repair.
    Pull it out, tear it down, rebuild it right and you get another 25 years from it..
    Don't try and diagnose from the outside noise!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    114
    yeah im gonna adjust the valves and timing chain then if its still there im going to pull the side cover off and see if there is any play or damage in the bearings if not i have a parts motor i could use it needs a top end and all the stuff on the right side but i think i could make one good motor out of two
    Dec 2010
    S.E. Illinois
    1,178
    yeah, check it out and get it fixed when you can. at the very least, you could possibly get one good motor out of the two. i've been waiting to get mine worked on to find out exactly what the deal is and the time is getting close.
    74 HONDA ATC 70
    114
    yeah i might just get a parts bike with a good motor there dime a dozen here and i read your thread sucks they stole your bike and damaged it but its good you got it back
    HondaClaw's Avatar
    HondaClaw is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    Southern VT
    179
    I would cry if my machines made that noise, because I have no clue how or what to do once I open that engine
    3,415
    Still sitting on the fence as to whether I should sell my NOS 250 engine just for this very reason..
    Both my 250s couldn't be stronger at the moment, but in a few years who knows what will happen and I might need a good motor really bad.
    It's sitting in a box under my workbench at the moment..if someone offer me the money I want I just might, but to be honest I'm happy when everyone I offer it too turns it down!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
