Recently purchased a 85 350X that the clutch will not disengage completely.The cable is new and matches OEM in length.It is a Motion Pro and even has the extra adjuster,still not enough.Without the cable connected the clutch arm has a half inch before it contacts.I removed the cover and parts don't look worn.Supposedly it had a new clutch installed recently.What should I look for?Or could it be the plates are just gummed up,it does not slip.
