Originally Posted by
shortline10
You need a copper head gasket !!!
I like that too!
Your top of your cylinder may not be perfectly flat as well as the head; They may need to be resurfaced.
Sometimes cylinder sleeves stick up just a few thousandths and cause head gasket problems also.......
A spotless smooth surface, perfectly flat won't cause you any issues.
What bore are you on now or how many mm's or thousandths over stock size piston are you using? Not compression, the overage of the bore?
If it's been bored a bit, does the head gasket you run accommodate that size?
