Thread: Just bought a 350x, couple questions.
    Aug 2010
    web
    79
    Just bought a 350x and was curious if anyone has had experience changing over parts from newer quads or dirtbikes. I'm needing a front brake line and curious if any dirbike or other atv has one that would interchange and be about the same length? Also if there are any other interchangeable common parts please feel free to post up.
    AJZ_200X's Avatar
    AJZ_200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    GRAND RAPIDS MICHIGAN
    363
    Ive got an extra brake line for an 86' (also fits on 85') if you need one. $20.
    I have used a gsxr street bike line to extend my rear brake line for my extended swinger, and it works great. You will need to change out the banjo bolts to bolt onto caliper correctly.
    Aug 2010
    web
    79
    thanks, i'm going to check on mine and make sure it does need to be replaced and i may hit you up.
    also i hit you up about some other parts, so that sort of worked out.
    sittinguy's Avatar
    sittinguy is offline Titanium Balls Arm chair racerAt the back of the pack
    Dec 2003
    343
    Here are some very nice ones on Ebay
    http://cgi.ebay.com/ebaymotors/ATC-H...item588dd90d14
    Aug 2010
    web
    79
    I ended up pulling all the crap and tape off and everything seemed fine. I put some steel braid on mine and everything seems fine.
    before
    after
    Western New York
    58
    Can't go wrong with the steel braids!
    Own:
    1984 ATC 250R
    1983 ATC 200X
    1985 ATC 250SX
    Trike Fest 09 Survivor
