Hi Guys,
Im looking to order a new drive chain for my 84 ATC110 to keep as a spare, Can anybody tell me what length I need to order.
Thanks
Hi Guys,
Thanks
Hi and welcome.
Manuals are free in the world class help section and the owners manuals and
sales brochures are fun to read too.
Chains?
I've found they are usually longer than needed and need to be cut to make them fit,
unless they are the 'right' size from the source.
There's a term called 'chain breaker' or similar, that is a tool with a screw-in
punch type thing that supposedly will spearate chain links.
I usually grind them off and use a punch to drive the pins into a 'chopping block'
of firewood and then use, what's called the 'master link' to reconnect.
Someone on here surely knows the right answer.
I guess you could count the links and try to match it that way.
Your chain size is 428 / 92. 92 meaning 92 links.
Thats the size for my 125's. And i'm positive that the 110's are the same.
You will have to buy a 428 / 100 and cut it down with a grinder.
You can count the flat plates on your chain. Then just multiple by 2 to to double check..
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
Thanks thats just what I needed to know, Cheers guys!
