Results 1 to 11 of 11
Thread: hey fellas i got a few questions?
    keggs17's Avatar
    keggs17 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2011
    IL
    170
    iv seen a couple guys on the thread that have lifted big reds, i found a 250sx....i would like to lift it. is it possible?
    ATC RDR 17
    "Inventory"
    1987 Yamaha BW 350
    1986 Yamaha BW 200
    Dec 2010
    S.E. Illinois
    1,178
    i don't own a big red, but i have been researching stuff for my buddy on it. yeah you can lift it the same as a big red, basicly they're the same things. just ones sporty and other is utility. somewhere there's a thread where someone even did a "body lift" by stacking and welding the top section of one frame to another. lifted the tank, seat and fenders.
    74 HONDA ATC 70
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    Sarnia, Ontario, Canada
    3,415
    Be careful about your choice to lift the rear of the SX..the shaft drive system relies on a u-joint equipped driveshaft between the transmission output and differential..
    Too much lift will place an increase angle on the ujoint that will cause it to bear additional stress or even cause premature failure!!
    I considered it on my 250ES after reading the thread that exists here on the site..but chose not to after considering the implications.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    +1 yes the implications are so true, i seen a trx250 with 26-9-12's and the drive shaft angle was changed so much, oh i guess thats why it broke much faster then it would without the ''lift'' .
    Carefull on how much you raise your machine, IMO if you want it to by taller, get a set of bigger tires that wont change the downwards angle on the drive shaft.
    keggs17's Avatar
    Aug 2011
    IL
    170
    Quote Originally Posted by dougspcs View Post
    yeah i was wondering about that, i had to fab out my 76 blazers rearend after i put the 12 inches of lift i changed the angle of my drive shaft. im only thinking about adding +3 inches under the rear mono. u think thats to much? it didnt seem to affect the other fellas big red and he was going through some deep and muddy s***?
    ATC RDR 17
    "Inventory"
    1987 Yamaha BW 350
    1986 Yamaha BW 200
    keggs17's Avatar
    Aug 2011
    IL
    170
    yeah i changed my mind about the sx. im to into the bigreds anyway. but i do need to know what all was exactly done lift wise? how do you extend the forks about +4 inches? what kind of bracket am i going to have to make under the rear mono to lift it up about +4? and what kind of steel should i use to make the bracket? I want to start on this project as soom as i can so help me out fellas
    ATC RDR 17
    "Inventory"
    1987 Yamaha BW 350
    1986 Yamaha BW 200
    3,415
    Quote Originally Posted by keggs17 View Post
    Many of the other members have discussed replacement of the front forks on the Big Red and the 250SX. 250R and 350X front ends have been substituted to accomplish the extension you want. I'm not sure it totals to 4" though..I thinks it's around 3"
    As far as 4" rear lift..that would be insane. You would trash the ujoints for sure at that angle. The fabbed bracket I saw only extended the shock mount by 1 or 1.5 inches..I wouldn't even consider more than that!
    Quote Originally Posted by 1984 honda 200s View Post
    Big tires doesn't increase driveshaft angle!! Unless it was lifted and bigger tires??? Is this what you mean?
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    keggs17's Avatar
    Aug 2011
    IL
    170
    here is the link for the bracket im wanting to fab. it looks closer to 2 in is this the one your talking about?
    http://www.3wheelerworld.com/showthr...-project/page2
    ATC RDR 17
    "Inventory"
    1987 Yamaha BW 350
    1986 Yamaha BW 200
    3,415
    That is a different lift, but same principle..
    I liked the idea, but was afraid of the damage it may do..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Sep 2011
    Illinios
    149
    Kegan, hit me up when you need brackets/welding, I have access to steel and a water jet. O ya I can gusset the frame too.
