wtb 450 foreman 4x4 part 2002
need battery hold down / seat bracket all the same part 806-674-8870
Hi,
I also have a 450 Foreman and I'm a member of the Foreman Club which would be a better place to start!
http://www.hondaforeman.com/
However, would I be correct in thinking you are after the bracket that has the 2 rubber mounts in it? where the seat plugs into at the rear??
If so, you are best to buy NEW, the plate/bracket is only $4.96 and the rubber mounts are $4.48 each!! Not worth searching for them used as they are available
to buy from Honda.
//ArrowChat Integreation Code
