Results 1 to 3 of 3
Thread: Inverted fork tripple tree need your opinion
    tippmann's Avatar
    tippmann is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    canada quebec Lac st-jean
    161
    Taking a stock tri-z tripple treee and a stock bike tripple tree(w/e bbike) with fork
    1: cut 4 hole of the tripple tree and cut stock tripple tree hole then weld( By a nice alu welder) Bike hole to the trike tripple tree.
    =Simple keep clamp for the handle bar and the hole for bolt to tight the fork
    need your opinion About the making of the project and the solidity (remember by a nice welder with Full penetration should be solid as stock.
    Tri-z 1985 resto project
    Arctic Cat Prowler 440 90 --- raised handlebar -Homade cherry bomb exhaust ! - Custom Tuck tape seat cover - Sled Mod by SREDNECK
    Kawasaki Z1000 04 -- Offmarket front disk - Yoshimura tr-s carbon slip-on- Bmc air filter- Power commander 3- Airbox Mod- Inc flasher tail light-Action pro steering damper-
    IM FRENCH so sorry about all thoses grammar mistake o.O
    Nov 2006
    southern oregon
    2,338
    you will need a jig or fixture for alignment. When using aluminum i prefer overkill(like new billet clamps)for piece of mind, but others have done it this way. You may have issues with the rake if your forks are leading axle.
    2-stroke lover
    Las Vegas, NV.
    2,516
    Quote Originally Posted by tippmann View Post
    I did my triple-clamps via this method. I haven't had any cracking issues, so that is not a problem in my opinion. I retained the same rake while going from trailing axle to leading axle, and now I have some undesirable handling/steering traits. Needless to say, I think I've done my homework the second time around, and designed some new triple-clamps with no rake in them that are being machined out of solid blocks of 1.5" 6061 aluminum.
    Even with a nice jig to support & align everything, it is a royal pain to keep the triple-clamps perfectly straight while having them welded. You'll have much better (read accurate) results getting completely new triple-clamps machined than if you welded them.
