Have an 81 atc200 have recently rebuilt carb and mixture screw is set per the initial adjustment after rebuild (have not hooked up a tach yet).
My question is it has been running fine for the past week....last night I took it for a short run down the road ran great. Come out this morning and it started up fine and made it halfway across the yard then died. it will start up but will only idle. When I try and throttle up in neutral it dies even when trying to throttle up slow. I choked it halfway to see if it was starving for gas and it acts the same. I adjusted mixture screw a little both ways with no luck.Dirt in carb maybe? It was cool last night and still is this morn could temp be causing problems?
Any help greatly appreciated.
