Results 1 to 15 of 19
Thread: Crank Bearing Spun On Crank
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Hi Guys! I couldnt post in the world class help section , So I guess ill post it here. I have a 1985 Kawasaki Tecate 3 that the magneto side crank bearing spun on the crank. The crank just had a new Hot rod Con rod installed with little wear on it. I had 2 old crank oem ones that came out of my 83 kx that fit. SO I thought it was the all Ballz bearings that had another bearing number. SO I bought oem ones. Well turns out they slide on easy too on the one side. Is there any way to repair this? Or is my crank garbage?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2002
    1,838
    Can Anyone help me out?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    I wish I had an answer for ya Dwayne.
    Nov 2002
    1,838
    Well at least someone replied.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Oregon
    2,471
    I have heard of machine shops putting in a sleeve on the main bearing case's, but they must have experience!
    Contact Carlos at - www.bdtmotorsports.com
    He's one of the few who do this job.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    By how much?? The crank half can be knurled and or cylindrical loctite can take up .010 (which is huge), easy..........
    A sleeve would be great, just not so cheap; But, the best way to fix it.......
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by ben6626 View Post
    luckily for us tecate guys kawasaki used the same 250 crank from around 81-82 through sometime in the 90's making them plentiful. there is a difference from the early to the later ones but it's just how the drive gear is secured to the crank(nut vs. clip)
    the KX stroke was lengthed to 70mm in 1987.. the crankwheels are too large for a T3 crankcase.
    Quote Originally Posted by Tecate250 View Post
    many will disagree, but i would press the newish rod, bearing, and pin into different crankwheels that are good...
    2-stroke lover
    Jul 2011
    Lilly PA
    1,480
    I just took a crank I had lying around in my spare tecate parts and had it cleaned up and got lucky that it was still in great shape. I didnt know the other options other than just getting a new one( or good used one). I think if you go that route try someone on here before going to ebay because 3ww guys are alot more honest than so schmo you dont know! Good luck on your journey whatever path you may chose!
    Just sit back and chillaxx
    Nov 2002
    1,838
    Well you see a used crank your takeing a risk on it. I was told to punch marks on the cranbk and use liquid steel to (glue) the bear to the crank.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    sounds like a bigger risk than a used one.
    I'm going to agree with Ben. I think you'd be better off with a used one than "glueing" a bearing on or whatever.
    Buffalo, NY
    1,996
    Its not a tractor engine, this thing is going to be spinning 9000+ rpm. That shaft will find the uneven spot on your junkyard fix and take out the crank seal as the best case scenario. There is a time and a place for rigging, this isn't it.
    Nov 2002
    1,838
    Thats great for people who live around other Tecates. I have the only running one in all the atlantic provinces. So take a 150$ crank shipping charges and border taxes ill be into it for about 200$ Plus finding one that can be shipped to Canada. Seems alot of americans dont like selling to Canadians. The bike ran fine with only one crank bearing connected only issue was the crank had left and right play. On top of that Im pretty broke.
    Thanks for the advice.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Sep 2006
    Northwest Indiana
    1,893
    All T-3's use a 64.9mm stroke. First and second gen cranks do not interchange however. Nor do 85 up kx cranks. You need a 83-84 KX or 84-85 kxt crank. Water pump,crank throw, P/V drive, case volume, and engine dimensions are drastically different for any other application, thus crank wheels being different. Rods however are all dimensionally the same, and can be used for any KX250 78-06 regardless of what oem #'s show. If you feel the big pin holes have become "loose" the pin can be lightly tig welded after final assy and true. It's a common practice on multi cylinder 2 strokes to ensure phasing it kept accurate and reduce the chance of twist. On single cylinder app, phasing is no concern. It's simply to ensure you don't harmonically walk the pin......
    Dwayne, you always ask for advice and then argue the answers. That may be why people were hesitant to answer initially.
    I may have a crank I can send you just for shipping costs. I'll have to take a peek.
    Oregon
    2,471
    WOW what did you expect Some Red Neck fix's with duct tape LOL...
    Just giving you crap, Best to SAVE up for the Correct Fix's.
