Results 1 to 15 of 30
Thread: 200x hard to start stumped !!!!
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    ok so i got this 200x . and its very hard to start . it will start on full choke eventually . run great idle good then crap out . or even if it stays running i shut it and its impossible to start again.
    motor has a new carb , 10:1 piston , fresh top end . good spark , timing is dead on , after it runs for a few mins the plug comes out black but dry .
    any ideas to make it start easyer ? thanks for any help
    84 200s almost done
    84 atc 70 project
    6,808
    How's the spark right after it wont start ? Might be the stator starting to go bad . Check your valve clearances also .
    Nubbinz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Winchester, VA
    171
    It could be the carb, bad gas, clogged petcock, nasty air filter, I know you said it has good spark but the plug could be fouled enough to effect it but you can still see a nice spark. At 2 bucks id wipe off or just replace your plug. Just figgured id throw some easy checkpoints your way
    Lauderdale County, Alabama
    2,029
    Check your valves.
    May 2011
    eden,ny
    3,481
    you said after running a few minutes the plug is black,a few minutes in what throttle position? idle? 1/4-1/2? 1/2-full? what is the carb you put on? jet sizes? it sounds to me like a carb issue but I would also test that the stator is within specs since that is also a possibility
    Jun 2011
    Conroe
    83
    try to run it w/o a air filter air/fuel ratio might be messed up due to biger piston
    Feb 2009
    greentown PA
    389
    valves are good , air filters good , spark after it stops is good , i bought the carb off of ebay im not sure of the jet sizes
    its black after only a few mins of ideling . i put a brand new plug in it
    its getting really frustrating lol
    84 200s almost done
    84 atc 70 project
    May 2011
    eden,ny
    3,481
    pilot jet and or mixture screw adjustment
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by PAPA250r View Post
    Was it one of those cheap aftermarket carbs some people sell on ebay?
    Feb 2009
    greentown PA
    389
    Yes it was one of the cheap carbs .
    84 200s almost done
    84 atc 70 project
    Nov 2010
    Coos Bay, Oregon, United States
    254
    adjust your pilot screw according to the book (2 1/4 turns out i think) and try adjusting it in from there, if that doesn't do it go to a smaller pilot jet. How does it run with the throttle held open when riding?
    mine: 85 Honda 350x
    http://www.Jeep4PlayOffroad.org
    Feb 2009
    greentown PA
    389
    I didnt get to ride it much yet in fear of walking home lol I just realized that I used the old slide that was conneted to my throttle cable . Maby this has something to do with it ?
    84 200s almost done
    84 atc 70 project
    N/A
    5,818
    bet your intake valve is tighter then all hell.
    Feb 2009
    greentown PA
    389
    I just put this engine together and I clearenced the valves to .003 .
    Double checked the spark and it looks kind of weak.
    If I turn the engine slow by hand it dosent even spark. I have to really whale on it to get a hot spark . Not sure if that's normal ?
    84 200s almost done
    84 atc 70 project
    6,808
    Like I said above your stator is going bad . Have seen it a 100 times LOL . You can also double check your pulse generator gap .
