Results 1 to 13 of 13
Thread: atc90 disk brakes?
    Oswego, IL
    1,858
    atc90 disk brakes?
    has anyone got any new set ups to show? i plan on gettin a mechanical brake caliper and coverting my brakes to disks! i would just like to see what other have got! and what size disk was most popular and maybe some tips on the linkage set up (with pics would be great) thanks for anyone that chimes in
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    MN
    632
    Quote Originally Posted by vartiak15 View Post
    check out this thread....
    http://www.3wheelerworld.com/showthr...eak&highlight=
    Jul 2008
    MD
    911
    I am running a 200x rear disc on my 90.. Using a Kx85 rear caliper, master cylinder and brake hose. I made a bracket to mount the caliper. It is currently apart in my garage right now or I would take a picture. It works great, but does lock up the rear wheels very quick.
    Oswego, IL
    1,858
    how did you mont the disk? did you turn down an atc90 brake hub and then weld a bracket to it?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    OK
    5,450
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Oswego, IL
    1,858
    nice pics now did you turn down a stock hub and make a mont for the disk? or did you get the trike with that set up on it? pm me if you ever wana sell any of them parts!!!!!!
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    and in the third pic the exhaust blocks right were i wanted to see does that rod just attach to the stock pedal?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    OK
    5,450
    yes.. I bought it all together with the rear disc brake.
    Rides:
    My feedback thread
    Jul 2008
    MD
    911
    For my disc brake setup I used an sprocket hub from another atc and it fit the splines perfectly. It did need a small spacer to take the place of the brake drum.
    Oswego, IL
    1,858
    do you know waht atc hub you used and what year axle do you have with your set up?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    anyone got a 200x brake hub layin around to measure and see if this is what works?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Jul 2008
    MD
    911
    It may have been a 200x hub. I know I used a 200x rotor. My axle is from a 1979 atc 90
    florida
    186
    a 200x disc will slide on the axle , may need a small spacer not sure yet? guess it depends on caliper that you use.
