81 atc 200 with 65.50mm 12:1 Wiseco piston, stock cam(xr200 cam will be put in later) ported and polishied head along with manifold port matched to the head. Got it running again and it has a lean stumble off idle. I've been looking at some 30mm carbs on ebay and found a 30mm carb with an accelerator pump. If I were to go with an 30mm carb should I go with the one with an accelerator pump?
Exhaust pipes are kinda hard to come by, will one of a 200x fit my atc 200?
