Results 1 to 3 of 3
Thread: 185s No Spark! Bad Stator which coil is the primary one???
    Wisconsin
    118
    I have a 185s always started on 1 pull now nothing I'm positive its the stator I know theres two different coils ones wrapped and one isnt which one is the primary one for the spark?
    Jul 2006
    western ny
    3,366
    The one with the red and black wire coming off it is the one you want.
    GIT IT RAAAGGGGG !!!!
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    +1 exactly, but since your this far, can you see any OIL around the flywheel? It should be Dry under it... Since your this far with the flywheel off and about to change out the stator( its the small top coil, the larger one on the bottom is for lighting) i would go ahead and pull the crank case cover off and change out the crank shaft seal ( its the big seal that sits in the middle of your case cover) This will save ALOT of head aches in the long run. Im about to change the coil and crank seal on brothers 185 tomorrow morning too. My reason for changing it out is because of a leaky seal that shorted the coil, this has happend to both my 185 and 200s
