Results 1 to 3 of 3
Thread: Triz 250 front wheel questions
    Aug 2011
    St.Louis
    3
    I'm looking for a aftermarket front wheel for my triz but having trouble.
    Dose anyone know the size of the stock axle so I can try a different wheel?
    I am just going to be drag racing this in sand so strength dosn't matter a whole lot.
    I need a 10" wheel by 4" wide so I can run a 19x6 smooth buff tire.
    Just looking for any help if you know specs on the Oem parts or if you know of a wheel for sale some where I appreciate any help
    switch the front hub to a 250r and run a 10" rim.. you'll have to shim some stuff.. .. or run 85-86 250r front end... with 86 tri-z tripples.. with a 10" - or 11".. no aftermarket 12"
    Aug 2011
    St.Louis
    3
    So a 250r three wheeler hub will work with the factory tri z set up and I'll just have to shim the hub some?
