Quick question between downs. Found a pair of 10x9 Douglas blues on CL, 4 110 bolt patter. If I am running 9x9 with 25 12 9 tires on my 85BR, will these rims work with the tires? If they do, what will that net me on my trike?
No, they will not work with your tires. A 10x9 wheel is 10" diameter x 9" wide. Your current tires are for 9" diameter wheels.
Thanks, I had it backwards. Is there a big difference if I start running a larger diameter rim?
No difference. Except tire selection
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
Also,,you can't go smaller. Unless they're big bell,,because of clearing the brakes in the rear.
