Results 1 to 13 of 13
Thread: 1986 Honda 350X No lights
    Feb 2003
    New York
    619
    Headlights and tail light were working. Now nothing works.
    Here is what I checked .... any tips or advice appreciated.
    Opened headlight checked for corrosion no corrosion
    Light bulbs do not look burnt. Filaments in bulbs look ok.
    The switch on the handlebar. On off switch for motor works.
    Tried Hi Lo On off for lights nothing.
    What type of tester do I need to check to see if a current is going through the wire ?
    I have one of them testers for inside the home but I dint know if it will work for DC.
    ♠ 58 ♠
    Ride 3
    NEPA
    7,049
    It will work,,sounds like the switch,,very slowly play with it ,see if they blink,,then clean out w ether or contact cleaner . If that doesn't work,,wiring.
    O.C., Oregon
    921
    Your tester should work, if not just go down to harbor freight and pick up a cheap multimeter to read the DC voltage.. I would check to make sure your AC regulator is still in good working condition, when they go bad you won't be able to keep a light on to save your life!!!!
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Crest California
    3,014
    Does the 350X put out DC or AC current?
    LED obsessed
    2015 Yamaha FJ-09
    Feb 2003
    New York
    619
    I was thinking the same thing maybe the switch. I will go through everything until I can find whats going on with this thing.
    ♠ 58 ♠
    Ride 3
    O.C., Oregon
    921
    Yep, its generated as AC, and changed to DC via rectifier (diodes), which is sometimes a separate unit, and sometimes its built into the regulater...
    2017 YZ 250x- Braap
    Feb 2003
    New York
    619
    Took apart the switch today and still no go after cleaning. Where do you recommend to get a regulator ? Ebay ? Prolly all used I guess ........
    ♠ 58 ♠
    Ride 3
    Tucson
    1,652
    You need to make sure all wire connections are clean (lightly sanded ) as these can create alot of issues!
    NEPA
    7,049
    Bad reg will BLOW your bulbs.. Don't just throw parts at it! Troubleshoot it. I really would have bet on the switch,,being BOTH head and tail quit at the same time. You need to OHM out your lighting coil, Should be a manual available thru this site . It will tell you the color codes and resistance needed. Then you'll know where you're going,new lighting coil,or wiring.
    Feb 2003
    New York
    619
    thanks the bulbs are not blown. I will check the rest of the wire connections.
    I tested the switch and there is no current going through the switch for the lights but the on off switch for motor works. I cleaned it out really good. Still same issue. Just really odd how it all went down at the same time. Maybe the switch is shot......... I will check out the manual and take a look at the lighting coil and wiring.
    ♠ 58 ♠
    Ride 3
    Feb 2003
    New York
    619
    found out what the problem was. It was the roost boost. It had wires exposed insulation cracked wire was touching itself and wiring at clip was loose. Removed it and plugged back into harness. Its all good now. Thanks all for the advice.
    ♠ 58 ♠
    Ride 3
    NEPA
    7,049
    Did you TELL us there was a Roost Boost hacked into the wiring!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Glad you found it... ALL the info saves us ALL a lot of time !
    Gold Hill, OR
    1,295
    Take that roost boost and give it to a homeless guy.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
