Thread: How to put larger wheels and tires on a 200s
    Sep 2011
    Barrie Ontario
    38
    I want to put 25 or 26 inch tires on my 200s. I cant find a large tire for an 8 inch rim. What options do I have. Can I change the hubs to fit a more common bolt pattern rim. I found a cheap set of ITP rims with 26 blackwater tires but they are 4x110 rims.
    1984 200x
    1985 200m
    1984 200s
    Nov 2010
    Oshawa, On, Canada
    2,123
    Don't quote me on this, but im fairly sure you can put hubs from a 250sx ,es, 200x, onto your 200s. Which would make it a 4/110 bolt pattern .
    Someone else will chime in...
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Lauderdale County, Alabama
    2,029
    You would be correct. Hubs on my 200es, 200s, and possibly the 250es will interchange for larger tires.
    Oct 2007
    Minneapolis mn
    4,067
    250ES/SX hubs are rather specific due to the shaft, and drum....
    Nov 2010
    Oshawa, On, Canada
    2,123
    Good point Thorpe. I never thought of that. Surely the 200x will swap?
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
