Results 1 to 11 of 11
Thread: whats wrong with my 250R? (Video)
    Winnipeg Mb
    113
    Hey guys, first off its a trx250r, but if the machine was a atc250r i woulda baught it also, why does my machine sputter in first and a bit of second, like it has a rev limiter? Stock pilot (48) with a 162 main currently. Running 32-1 with 91 octane and ipone synthetic oil. any help would be great i love this ol honda so much. Im 17. At 1:50 you can hear what I mean very clear
    250r Video
    1988 Honda TRX250R
    fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
    1985 Honda Big Red 250ES
    1984 Honda Big Red 200ES
    1982 Yamaha Tri Moto 175
    Please Check Out My Youtube Channel
    http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    your on and off the throttle way to much .. too much hurky jerky going on... i would go down on the pilot one size and drop the needle one notch.. and try to be alot smother on the throttle .....
    Winnipeg Mb
    113
    i didnt think i was on the throttle too much.
    1988 Honda TRX250R
    Crest California
    3,014
    Yeah you're really tweaking out on the throttle. Also did you give the bike time to warm up? A lot of riders like to let the bike idle away for a couple of minutes so it can warm up.
    Sounds like your jetting is a bit rich, maybe by one or two jets and it's loading up on you. I would try one jet size smaller on both the main and pilot, then do a plug chop.
    LED obsessed
    2015 Yamaha FJ-09
    Winnipeg Mb
    113
    what am I looking for in a plug chop? That's where I actually cut the plug in half right? When I do check the plug the regular way its black and wet. I am using a iridium plug cross referenced with what Honda recommends as a br8es non iridium. The machine had been running for 30 mins prior to this being filmed
    1988 Honda TRX250R
    Crest California
    3,014
    I think it's about a 2mm wide copper ring at the base of the white ceramic cylinder in the middle. I think the electrode on the tip also is a decent indicator (a nice dark-ish copper color).
    LED obsessed
    2015 Yamaha FJ-09
    Blossvale NY
    4,563
    I concur with previous recommendations, sounds a bit rich on the pilot jet and slide needle to me. Possibly rich on the main too, but try stepping the pilot down one size and run it. If still rich in midrange, then drop the needle one position. If still acting like that, (which I doubt it will) step the main down 1 size. Make these adjustments one component at a time so you can zero in on the problem area of the throttle range.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Sep 2011
    Illinios
    149
    First off, love and watched all your vids, all the updates where awesome! Subbed to you! And sounds likes it's cold? Or ya listen to kasey.. The guy knows his s^%#
    I hate quads.
    Sep 2011
    Illinios
    149
    Fabio... When I see that you posted i kno I'm about to laugh!
    KASEY's Avatar
    4,244
    Sorry but i do not see anywhere in the video that he was on the throttle long enough to even think about changing the main jet,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,
