Havnt saw these on many others curious as to if they were original or any info on them.
Back in the day, my bud had them on his 185s. They are just to lengthen the wheelbase a little bit. But does change the handling characteristics a bit too.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Ya I have not seen many with em. Are they worth leaving on....or something I should remove?
All I can say is its up to you. Try it with them on, then take em off and see which way you like better. They will help you a little bit if you like to play on hills.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Ok ya that makes sense it climbs hills well...sure they arent making a huge difference but even if they help a little....
So Honda just put em on a handful of models I'm assuming? Using them on trikes with racks would make sense maybe but this one didnt have them before I got it.
The purpose of the fork extensions was to move the front tire away from the fender. Without them, when mud balls up on the front tire on some trikes and it will hang on the fender and stop the front wheel from turning; and then you loose what little turning ability you had in the mud. Those extensions keep the tire far enough from the fender to prevent this.
1974 Honda ATC 70
1985 Honda ATC 250 ES Big Red
1986 Honda ATC 250 ES Big Red
2008 Honda Rancher 420
1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
2010 Chevy Silverado 1500 4x4 LT
1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
There is no Z in Diesel!!!
these were a common aftermarket part and most interchange and fit the 90-110-185 and 200 with solid forks i run them on all my trikes they handel way better with them on
ACT NOW THINK LATER!
current trikes owned
minty 86 250sx my rider
pauter flat track framed 110-123cc with custom goodies
pauter mx framed 110-123cc with aftermarket goodies
joker framed 90-108cc with front suspension
2007 artic cat DVX 400
dickson sprint framed 73 green us90 with 110 engine
Ihave a set if some one needs a pr.! they came off a '81-110 atc..........
DO the Best With What you got !
My Feed back :cool
1974 Honda ATC 70
Great thanks for all the info!
