Results 1 to 7 of 7
Thread: Clamp on Air Filter for Tri Z?
    May 2003
    Houston, Texas
    2,409
    Hey what are you guys using to clamp on a K and N or foam filter to the carb on a Tri Z?
    I want to ditch the stock set up and run a clamp on.
    What works?
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Mexico
    9,014
    A foam Unifilter is what I have and always see. Gauze and paper don't work well when exposed to the elements. The Tri-Z is very cramped in that area, so I don't think there are many options.
    Sep 2011
    Illinios
    149
    I have a uni on mine... I usually run k&n with outer wear though
    Mexico
    9,014
    Quote Originally Posted by Addicted View Post
    Do you know the part # for that K&N?
    May 2003
    Houston, Texas
    2,409
    Exactly...anyone have part numbers?
    thanks guys!
    Dirtbikes:
    1988 Yamaha DT
    Mexico
    9,014
    Quote Originally Posted by Darius1502 View Post
    Are you using the stock Mikuni, or something bigger? I have a 38 Keihin, so I it's a little larger than a stocker would need.
    Try www.unifilter.com measure your flange and the distance from it to the rear shock and brackets (i think you need to remove the catch can as well) and pick one that fits.
    May 2003
    Houston, Texas
    2,409
    Thank you for the suggestion...I will do it!
    Dirtbikes:
    1988 Yamaha DT
