Results 1 to 13 of 13
Thread: HELP! is it possible to wire up after market lights on an ATC 185s????
    Sep 2011
    grand rapids, mn
    39
    Trying to wire up after market lights on my ATC 185s and can't get them to work. I've wire hundreds of automobiles and for some reason I'm stumped...
    It's very simple. Find 12 volts, find a ground, viola! What is it you are missing?
    Des Moines, IA
    1,303
    What makes you think the lighting circuit is working? Got a voltmeter or a test light? Check for voltage at the wires where the light connects. You should have voltages there with the engine running and the headlight switch to LO or HI.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Sep 2011
    grand rapids, mn
    39
    Couldn't find my multi-meter, but when I took the wire off the lights and tapped it on the connectors I got a little spark indicating to me there was power, I even tried a fresh ground and different switch just to narrow down the problem and still nothing.
    Quote Originally Posted by ben.simons View Post
    That's not really the best idea. You could have messed something up just doing that. I don't know what else to tell you. Find 12 volts, find a ground. Ta-daaa!
    Jul 2011
    Eau Claire, WI
    1,188
    Quote Originally Posted by ben.simons:1058279
    Gotta ask bro, sorry to do this. Did you wire the switch properly? 12v to neutral position and ground to the switched position?
    Jun 2009
    Leander TX
    2,217
    What kind of lights?
    I bet it won't run an HID / ballast light because 185s is an AC system.
    Anything more than about 40watts will be dim and maybe won't appear to be working.
    Do the stock lights work now?
    Fabio hit the basics
    Des Moines, IA
    1,303
    I was just going to ask some of the same questions. The stock system is AC, so anything other than just a plain bulb won't work without rectification at the least, and possibly a higher output lighting coil. The stock headlight is only 35w.
    You might find that purchasing a stock headlight from ebay or a member here is easier than trying to do something aftermarket. I find the stock headlight on my 200s plenty bright.
    Crest California
    3,014
    Well... You could always convert it to a floating ground, run a regulator/rectifier, a 12v battery and then plop in a 35W HID... Not sure if your stator can charge the battery though. Or you can run a pair of 10W Vision X LED's.
    LED obsessed
    2015 Yamaha FJ-09
    Nov 2009
    N Hollywood/ CA
    588
    I have a headlight & bucket that you can use, if you want it its your's. pm me
    the worm
    Nov 2009
    N Hollywood/ CA
    588
    Does anyone know if a honda 79 90cc or 110cc atc are 12V or 6V? I hooked up a headlight from a 200S, it works but when the bikes idle the light is dim, when accelerate, the lights gets brighter. Is that normal?
    Sep 2011
    grand rapids, mn
    39
    Stock light don't work. Bulb went and had the local cycle shop order new ones and don't fit in the glass. The guy I bought it from must have put glass from a different year on it and I can't find the correct bulb anywhere
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by bigworm626 View Post
    Normal. Careful if you don't have a tail light. These systems are unregulated. Well, actually, the bulbs are the regulators and if one dies the other one quickly follows on the next hi-rev.
    I'm not sure about voltages but I believe 70 & 90 are 6V, non-CDI 110 is 6V, and CDI 110 is 12V. 185, 185s, 200, 200s, etc are 12V.
