Thread: hi/low gear question.
    Aregistereduser is offline At The Back Of The Pack Arm chair racerFirst time rider
    new york
    187
    i read on another forum that the hi/low gear lever SHOULD NOT shift "on the fly" (gears 1-5) and SHOULD only shift in neutral but my 84 200es and my (belive 82 110) shift from hi to low and vice versa in any gear. is that bad?
    Jul 2011
    Eau Claire, WI
    1,188
    I believe it's fine as long as the machine is stationary. I shift mine while in first all the time. Don't quote me on it though.
    Sarnia, Ontario, Canada
    3,415
    They recommend switching in 'N' to prevent gear clash in case the engine revs have the clutches engaged..even just a little engagement will make it impossible to shift ranges or grind the gears.
    But you can do it if revs are low..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Dec 2010
    Back in VA baby!!
    711
    It's not that you can't, it's that you shouldn't. The hi/low really wasn't designed for it, by shifting on the fly, your not taking any of the engine torque off the gears when doing it. Your regular gears are disengaged by the clutch, but there's no clutch for the submission, hence the need to put it in neutral.
    new york
    187
    thanks! i usually stop and shift, but my 110 will probably need the gears gone through soon anyways the previous owner really tore them up. persume from pulling deer out the woods unresponsibly.
    Dec 2010
    S.E. Illinois
    1,178
    you can switch them when in gear, it's just not advised. on my 125 i figure as long as i'm not moving i can switch it, but if i'm switching it then 1st gear isn't cutting it so i'm practicly stopped already anyway.
    74 HONDA ATC 70
