Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: 400ex Carb on 350x PROBLEM
    Camano Island, WA
    361
    Hey guys.
    So my 350x has a k&N and a freeflowing exhaust, otherwise its stock.
    So i finally got a 400ex carb all rebuilt and put on my 350x.
    After 50 kicks it starts.
    I turned the pilot to 2.5 turns out and it doesnt really want to idle.
    you give it a tiny bit of throttle and when you let off it goes pum pum pum.
    when you give it 1/4 throttle, maybe a bit more, and then let off it goes pum pum BANG!!!! BANG!!! lotsa backfiring.
    So i turned the pilot out more, to 4 turns, still backfiring but idles a little better.
    I put a new plug in before i did this.
    Took the plug out and there was no black at all, white.
    LEAN right?
    But i cant adjust the pilot out anymore..
    Any clues guys?
    Thanks!
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Need new jets in the carb. What are the jets in your 350x carb? You need to do some trial and error probably.
    Also make sure there is no air leaks.
    edit; 42 pilot jet and a 165 main should help you
    edit2; bad fingers...
    Nothing to ride... for now
    Camano Island, WA
    361
    Im using the stock jets for the 400ex in the 400ex carb.
    Nov 2006
    Seattle
    1,552
    thats not much help, what are they?
    Camano Island, WA
    361
    The slow jet is 38 and the main is 148
    Nov 2006
    Seattle
    1,552
    have you made sure theres no kinks or bends in any of the cables?
    3wheely's Avatar
    3wheely is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Florida
    259
    Sounds like way lean to me. Do you have the stock filter to put on and try for now? K&N's allow a lot of air flow and will cause lean conditions. It might be enough to get by until you re-jet. I had to do this to mine.
    Camano Island, WA
    361
    Im thinking it needs jetted differently. With my 350x carb it ran perfectly.
    Cables are all fine.
    What do i need to change to get it to run richer?
    3wheely's Avatar
    Florida
    259
    On a stock carb and stock bike it's 1-3/4 turns out. Obviously it would be different with a 400ex carb, exhaust and filter.
    3wheely's Avatar
    Florida
    259
    Go smaller. It's trial and error. Buy a few to save time.
    Camano Island, WA
    361
    yeah, i have it at 2.5 turns out, but super lean still..
    Camano Island, WA
    361
    go smaller what? main jet?
    Why does twilight say to go larger on the slow jet?
    3wheely's Avatar
    Florida
    259
    I thought the further out the leaner it gets? Have you tried less turns? If still no difference you probably need to re-jet. Have you went to the technical section and read the thread about tuning and jetting? It's pretty helpful.
    Nov 2006
    Seattle
    1,552
    the jetting i gave should be the equivalent and will get you on a good start. run it on those settings for a ride, take out the plug and do a plug chop. From there you can either post pics of what it looks like, or you can go from there and find the perfect jetting.
    3wheely's Avatar
    Florida
    259
    They both do different things depending on the setup. Read up on that thread. It's very helpful. Jetting is never fun.
