Thread: question for guys running inverts on 250r with headlight
    Snohomish, Wa
    1,028
    I have a set of inverts that Jason hall modified and I mocked them up. I want to run a headlight and noticed that the headlight straps are short by a half an inch. just seeing what you guys have done to make it work. Worst case I will just figure something out but wanted to see if anyone had an idea about it first.
    any help is always great
    Thanks
    Tyler
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Las Vegas, NV.
    2,531
    I'm running KTM 85SX inverted forks, and I made a set rubber extensions for each stock headlight strap. I've often wondered what others are doing about this also. I figured stretching the stock straps beyond the limits they were designed for would lead to premature failure.
    Snohomish, Wa
    1,028
    Yea, I was thinking rubber extensions. I too was concerned with over stretching the stock straps and breaking if I could get them to stretch enough to work.
    86 TRX250r
    05 KFX400
    02 400EX
    Mexico
    9,018
    Based on a TPC photo I saw. I went out and found one on ebay by UFO (acerbis and others make them as well) that I put on my "ridiculous" three wheeler Might work for you and I think they come in a few colors. They were a little loose on standard forks, but I bet they would fit great on inverts.
