Results 1 to 14 of 14
Thread: Should I buy...250R
    pismorat's Avatar
    pismorat is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    San Diego
    207
    Should I buy...250R
    Going to look at an '85 Honda 250R today. Guy says last time he rode it the top end went out and says it won't run now. I am new into the 2-strokers, but have done tons of engine work, so what should I look for specifically? I'll check over the rest of the trike, but the top end is my main concern to how much it will cost to get back running. He's asking under $500 for it and I can't spend too much with a newborn in the house...
    O.C., Oregon
    921
    If it's just a typical top end job, usually around $200 to get her back up and running again! Take the plug out and see if anything jumps out at ya, but for less than $500 you can't go wrong really, especially if its in decent condition!!
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Crest California
    3,014
    I'd say hop on it quick! $500 you could make your money back easily. Or invest $2-300 in rebuilding the topend and double your money.
    LED obsessed
    2015 Yamaha FJ-09
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Besides rings and gaskets, what is "normally" involved in the $200 for doing the top end? If the piston and cyliner are shot, that'll be more money for a bore job and new piston?
    Blossvale NY
    4,563
    New piston, and if needed a bore job.
    Grab it. If it doesnt work out you can at least double your money parting it out.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    O.C., Oregon
    921
    new piston, rings, and wrist pin is about $140 gaskets are cheap and if the bores still good you can just hone it or get it bored to the next size if needed, about $200 give ot take...
    2017 YZ 250x- Braap
    Oregon
    2,471
    About $200 Piston Kit Gasket kit and Bore / Hone that's it.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Thanks for the help! I checked it out, its a little rough. Needs the plastics sanded, brakes worked on, and a top end kit (bore looks good). I'll be picking it up tomorrow for $350!!! Pics to come then...
    O.C., Oregon
    921
    damn good deal my friend!! You can't beat $350!!!!
    2017 YZ 250x- Braap
    NEPA
    7,051
    Congrats!!!!
    Snohomish, Wa
    1,028
    While you do a topend rebuild I recommend pulling the clutch cover and checking your counterbalancer bearings. Also when you got the topend off check your rod and crank. Make sure you dont see any copper chips. Sounds like a great deal. I remember when $350 wouldnt even buy a roller. Nice score.
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Baltimore, MD
    6,088
    If you gotta ask someone else if you should buy it, then you shouldn't buy it.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Sep 2011
    Illinios
    149
    I could agree more vealmonkey, I never buy anything if I'm doubting myse lf, nexus there's usually good reason! But good deal man!
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Only reason I was asking is to see how involved a top end rebuild would be...both in work and cost. Being new to 2-strokes that was the reason for asking. Pics are in a new thread.
