Well here I go again I blew my Honda 185s top end but I think Im just going to rebuild the whole trike here is what I am starting with. I will also post a walkaround video.
If anyone has any helpful hints before I get started please let me know.
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
My first question is will the engine come out of the frame without taking the top end off first?
Yes it will... Pretty easy too
takes about 10 mins to pull that engine
ok ill get started and if I have any problems ill hit yall up and thank you !
ok I hope I am doing this right but this is what I have done so far...
Motor still wont budge i must have missed a bolt somewhere.....
then...
few things i remember correctly.the following need to be unbolted
exhaust header and silencer
motor mounts:top of engine,front of engine,bottom rear mount,mid rear mount
shifter
loosen chain tensioners and move axle forward
electrical
carb.
Well I got it out now what lol?
Next I am going to take the side cover off. What do you think of that head?
Ahhh found the knocking problem hsve s look st thid!
check the video what could have caused this?
My question now is will a 200 fit in a 185s frame?
direct bolt in
Your timing chain sprocket looks screwed..looks like your timing chain was slapping around then jumped. Judging by the knock marks in the top of the piston the valve timing went off..
The knocking sound was the piston hitting the valve..look closer!!
The chain rub marks on the inside of the engine cover is the least of your problems.
Change your oil once in a while..look at the sludge in your engine!!
Junk engine!!!
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
i guess ill part it out,
