Results 1 to 6 of 6
Thread: 82 250r extended swing arm
    Sep 2011
    Ocean Beach, CA
    1,333
    hello all,
    wondering if theres a fabricator/welder on here that has experience extending a stock 82 250r swing arm +4 inches
    let me know whats up. thanks guys
    Apr 2002
    s.w. michigan
    6,498
    I have seen this fellas welding skills first hand. He has a knack for jig building + is extremely experienced in the field of swing arm fabrication
    There are some other folks on here as well that I would include in the professional class but Billy is first that popped into my mind when reading your post.
    http://www.3wheelerworld.com/member....illy-Golightly
    Rollingmenace is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    Colorado
    224
    there are several.. people who can do the swingarms..... but what i would recomend looking into using a swinger from a trx 450r it will net you between 4 and 4 3/4 inches depending on the year.... the 450 swinger only requires a few modifications to be made to fit and a big advantage is that it uses all the 450 rear end stuff which has great aftermarket support and the stock stuff is really cheap... and unlike the first gen 250r parts they will be around for the next 20 years'''
    i did a trx 450 swinger on mine and so far its been great>>> i did a write up on s dot com
    82 ATC 250R (AS $ Crusher.. Project 450 swinger)
    84 ATC 200X (Project Blackout) Hers
    86 ATC 250R
    86 TRX 250R (The Golfcart)
    87 CBR 1000F SSSA STREET FIGHTER
    95 NINJA 250EX
    My Feedback http://www.3wheelerworld.com/showthr...-Rollingmenace
    visalia
    Yes its very easy cut it before the bearing holder and install inside demintions size tubeing to disired lenth into the swing arm tubeing be sure that you check your lenths from bearing carrier to swing pivot holes plus check alienment from the same places then weld with a mig or tig but jump around to distribute the heat . fill in the differance with 16 gage plates its pretty simple Ive done this several times for ESR RACING extending and shorting ! good luck !
    Jan 2024
    Utah
    Quote Originally Posted by Rollingmenace View Post
    Sorry if this has already been asked but will a 450trx swinger fit on a second gen 250r frame
    Willamstown PA
    5,824
    Nope. Contact hreatv.com and get the correct one built.
