'85 ATC 250R
FMF Fatty & Power Core
Boyesen Rad Valve
38 PWK A/S
K&N w/PF (next purchase)
LSR +4 Axcaliber axle
LSR Duel row bearing carrier
DuraBlue Anti-fade (to be installed)
13/36 sprockets
'85 ATC 250R
Parts trike (maybe future build?)
Life is a lot easier with the right tools.
That looks like a general bearing installation kit, including blind bearing puller, nice to have.
You will still need a 20 ton press, an OEM shop service manual and various thin sleeves that can be made up of pipe of many sorts.
Realize, that you may not have the tools to do it, maybe you do?
Cranks have to be pulled into position without any sideload on the crank halves. Then they have crank holders etc etc, they can be done without but you have to "get" what can be damaged if you make a wrong move. There goes that rebuild that should last 25 years.......
Half the guys rebuilding 250R lower ends don't even know why (or if the even know) that the left crank seal needs to be set 4-5mm deeper than flush.
Lots of info in the searchable stuff, propane torches and a freezer are your best buddies
Don't neglect the counter balancer bearings and holder and bolts, they are just as important!
dam, no press here, 4' jack all lol maybe i should give it to a shop :/
'85 ATC 250R
Boyesen Rad Valve
38 PWK A/S
13/36 sprockets
'85 ATC 250R
Anytime I ever rebuilt a bottom end I put the case halves in the oven and heated them up and the bearings just fell out even the blind bearings. Then when I reinstalled the bearings I put the bearings in the freezer overnight and the next day I put the case halves back in the oven. I heat them up till when a drop of water hits the case half it steams. I then take it out and drop bearings in and they push right in with little effort. When it cools the bearings are set. I would avoid putting a open flame to your cases though. Just my opinion.
Same for me, but for some reason my last project ended up with one of the mains a little cocked. Someone here (I think it was Mosh) said that sometimes if you do the bearings like this they can squirm back out a bit as they cool. I got mine seated right after, but there were some tense moments I'd have paid to avoid. I'll still be doing my next rebuild like this, so I hope that was a fluke.
interesting, might just have to give it a try.... worst case, buy another engine lol or cases![]()
'85 ATC 250R
Boyesen Rad Valve
38 PWK A/S
13/36 sprockets
'85 ATC 250R
