Results 1 to 14 of 14
Thread: stock expanchan chamber Q
    May 2011
    Michigan
    109
    I was lookin at my 85 250r's expanchan chamber and was wondering has anyone attempted to gut it out? if there is anything in side of it i would like to gut mine, my buddy told me about guys doing this to there banshees and i was wondering is it possible?
    OK
    5,450
    I've never cut one open neccesarily but I'm pretty sure there isn't anything to gut. I think some oem pipes were double walled but don't think the 250r expansion chambers were.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    May 2011
    eden,ny
    3,481
    pretty sure it's expansion, nothing in there to gut out nor is there on a banshee. It would be the silencers they gut out. I wouldn't recommend it, I would just find an aftermarket silencer.
    Apr 2008
    NW, IND.
    842
    X2 Chamber is empty. Now if there is oil caked in it, I've use a small map torch to heat the pipe lightly to burn the carbon out.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Lauderdale County, Alabama
    2,029
    Quote Originally Posted by buzzy613 View Post
    my buddy told me
    There's those words again!
    And I'm pretty sure there's nothing to strip out, they aren't like the muffler on a four stroke.
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    If there is anything in it it won't work as an expansion chamber! It is designed to change the velocity of the exhaust gases at specific points in the cycle and rev range and its shape is critical to the way the engine performs.
    Whatever you change on a 2 stroke exhaust will definitely have an effect on the power. Different shape chambers and pipes give different engine characteristics. You need to be able to reverse whatever you do in case it doesn't work.
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    Blossvale NY
    4,563
    There are no baffles in a 2-stroke expansion chamber (header pipe). The expansion chamber pipe uses sound waves that reflect back from the far tapered end of the pipe before the silencer to aid in the intake/exhaust cycle. Different expansion chamber profiles will cause different power curves on a typical 2-stroke. Its all about the timing and strength of the return of that sound wave.
    In other words, its a fairly precise science that takes alot of know-how to customize. So, dont mess with it! LOL!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Mexico
    9,018
    Agree, but wouldn't the correct term be "pressure" waves? Maybe they are one and the same, or could both be in play inside a pipe? Damn this gr.6 edumacation of mine!
    Blossvale NY
    4,563
    Well, sound is actually a form of pressure. Im thinking one in the same in this case.....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    WilliamJ's Avatar
    Apr 2010
    Poole, England
    157
    You are both right because it is referred to generically as pressure wave tuning, and the waves travel at the speed of sound. Of course the sos varies according to the temperature, pressure and density of the air it is travelling through.
    By all means mess with it but do some detailed research first and be prepared to fail. So don't cut up the pipe you are using, make another. There was an expansion pipe calculator on here (Java Pipe: Tuned Pipe Designer is how it shows on my bookmarks) but I couldn't get it to work on my Mac and my windows machine is no good at the moment. Anyone try it?
    Bill
    Custodian of:-
    Blossvale NY
    4,563
    Quote Originally Posted by WilliamJ View Post
    Bill
    You hit the nail on the head.. Its kinda like porting. Yes, you can learn the science, but its gonna cost you a fair bit of time and cylinders to port, and try... trial and error. Not something your average shadetree mechanic like most of us can really pull off with any degree of success...
    Before i get pounced on, note i said MOST of us!! LOL! Im sure with all the collective experience in this forum's membership roles there are some who have the tools, know-how and experience to do this, and have done with success...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Michigan UP
    1,005
    Cut open a stack banshee pipe, they do have a muffler type set up in the chambers. It's possible the older trikes do to
    Mexico
    9,018
    I've only seen two vehicals with "stuff" in the expansion chamber. One was a John Deere snowmobile which I tried to "fix" and ended up with no bottom end and no top end, but it had a mid range bang that would lift the skies at least 2' off the ground on hard pack (steel channels running across the track). My Dad ended up paying the dealer around $300 for a new pipe so he could drive the sled again and that got me banned from the shop for a few months. The other was a 500 Yamaha V4 that I never cut open, but I could feel the baffels with a wood stick. I'd be surprised if a race oriented machine like a 250R had such obstructions in it.
    It would be something to see how a place like FMF determines how a pipe is to be made, but that said if any of you are old enough to remember all the different pipes available for the RD 350 back in the day and how when the magazines would test 5 or 6 of them, you'll recall that the stocker would usualy be ranked near the top in performance. That tells me it's not easy to build a better all round pipe than the one that came on your machine from the factory. I think most people just assume louder is faster without taking the time to test things.
    2,029
    I think Honda has proven that louder is NOT faster in the car division.
