Results 1 to 8 of 8
Thread: Decarbonizing combustion chamber and the ol' 'water injection' craze.
    Pacific NW
    4,255
    The engine flush thread got me thinking.
    I remember pulling heads off that had blown (water jacket)
    head gaskets.
    The affected cylinders were sparkling clean.
    Around that time (oil crisis) in the what, late 70's?
    Water injection was promoted to increase hp, keep engines clean and
    increase compression.
    They'd spray a mist into the intake when the vacuum hit a certain point.
    Ya know how engines run soooo much smoother on a real foggy day?
    Well that was the reasoning.
    They were commercially available units and kinda interesting. You could actually feel them kick on.
    Maybe I'll hang a sippycup near my intake somehow and report back.
    Mexico
    9,018
    Quote Originally Posted by drjoe171 View Post
    head gaskets.
    Well that was the thinking.
    I've tricked a water hose into a few engines. The first time I did it (on that same olds I ran gas through) a lot of gray vapor came out, so I was immediatly convinced this was the way to remove carbon. I've done it on other engines since and all I've seen is water come out the pipe. I guess the only way to know for sure if it does anything is pull the head(s) take some photos, button it up, run water through it and open it up again. I've also built and used a Water4gas gizmo, but that's a whole different story.
    PS. I would never attempt putting water a 2 stroke.
    Sarnia, Ontario, Canada
    3,415
    There is also commercially available spray products to do this..
    Solvent based cleaners that you spray into the intake or carb until the engine floods out..allow to sit a short time for the solvents to breakup the carbon buildup then restart the engine.
    Sippy cup in front of the intake..that's funny!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    hey, yes water works good for combustion chambers, but too much water can hydraulic the piston.
    one cylinder is not enough!!
    Oct 2007
    Minneapolis mn
    4,067
    Yamalube ring free fuel additive... So much easier... (and my trikes prefer beer to water!)
    Mexico
    9,018
    Quote Originally Posted by dougspcs View Post
    and a diaper under the pipe to catch the drippings!
    3,415
    But then we aren't kids anymore and this isn't dad's old 3 on the tree '77 Ford pickup..you know flip the breather cover so it make that woosh sound when you hit the gas, high test fuel and tweek the timing ahead just til it pinged, maybe even an occasional flaming backfire out the carb!!
    Bumpkin tactics like water in the intake are old..just like tipping the machine to change the oil. Times are different..there are better ways of doing things now!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Jul 2011
    Eau Claire, WI
    1,188
    I spray Seafoam Deep Creep in the intake and occaisionally will pull the splug(s) and spray in there too.
    Great stuff if you have an EGR equipped engine.
