Results 1 to 3 of 3
Thread: 200M wierd issue
    Mr.Jake's Avatar
    Mr.Jake is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Ontario
    192
    Angry 200M wierd issue
    ok, i can usually figure these machines out but this one has me stumped...
    I have a 200m that will idle nicely all day long, but boggs when given throttle.
    I rebuilt the carb with the same outcome.
    Put on a carb from another machine with the same outcome.
    New plug, gas, the whole bit.
    When i adjust the carb mixture screw nothing really seems to happen, still boggs no matter what. I checked timing and valve clearances and all was good.
    There didnt seem to be much exhaust coming out of the pipe and the engine got hot fast, so i removed the exhaust and the bike ran great, lots of power, good throttle response. So i cut off the muffler portion and didnt want to keep it loud so just attached a lawnmower screw in muffler deal to the end, bike bogged as it did before. I drilled the center of the muffler straight through 3/8", same bogging issure. Is the muffler just creating too much back pressure still or could it be another issue? I've got a buyer for the bike but want to make sure it runs well before i sell it.
    Thanks, Jake
    83 Yamaha 225DX
    84 Yamaha 225DX
    84 Honda 200s
    78 Kawasaki 175 enduro
    83 Susuki LT250
    02 Bombardier Traxter
    Sarnia, Ontario, Canada
    3,415
    Check that the mechanical spark advance is working properly..
    I just had a similar experience with my 185..
    Pulled the CDI cover off and tapped it, ran great for about 5 minutes. Then started again..shot some lube at it and seems to have cured.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Nubbinz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Winchester, VA
    171
    Could be electrical as stated above. Have you cleaned or replaced your spark plug? It could be a weak coil too. Have you checked the actual exhaust pipe ? Its like a half inch in diameter, on a Honda car that would be clogged after one night at the drag strip. Its viable after 20 some years its clogged on yours. Also, have you tried throwing a coffee can on that beast ? I think a trike with a fart can would be awesome.
