Results 1 to 8 of 8
Thread: Permatex Thread Locker (red) vs Loctitie (Red)
    Sep 2011
    Monroe Louisiana
    73
    Long story short - I tore down the tilt steering column of my 85 CJ7 to tighten up the bolts that stabilze it (steering wheel would literally wobble in every direction). I dont ever want to tear this blankety blank blanker down again. I went to the local auto parts store for Loctite (red) but all they had was Permatex Thread Locker (red). I picked up the Permatex and am now wondering if its as good as Loctite.
    I know Loctite is good stuff but have no idea about the permatex - was hoping someone on here had used both and could give some real world advice on which is the best.
    Aug 2010
    Southern Oregon Coast
    932
    same stuff I'm pretty sure. Loctite is just a brand
    Jun 2009
    Leander TX
    2,217
    Is that for the 4 little torx head bastards buried deeeeeeep in a GM tilt column? I hate that job...
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    The Permatex will be fine. The red 271 / 277 is their high strength which will need heat to dismantle.
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    Pacific NW
    4,255
    This is 20 year old info but red locktite is considered permanent.
    MAYbe used for like ringgears and heavy suspension stuff but nothing into aluminum.
    It will take out the threads.
    Blue was more for stuff you may want to take apart someday and then
    there was 'wick and lock' green and watery.
    A drop on the threads AFTER I tightened stuff and forgot the locktite.
    Now I use nailpolish because nail polish remover melts it, if I don't have the correct locktite.
    WilliamJ's Avatar
    Apr 2010
    Poole, England
    157
    Red Loctite will still soften with heat and at a lower temperature than aluminium anneals. The Loctite range is so big it's hard to i.d. stuff by colour any more but I recall red being a lot less permanent than the evil green I used for making sloppy bearing housings good. (It was labelled 'bearing retainer') Even that would break down with heat but it took a lot more heat.
    I use a quick-setting white Loctite for all regularly removed engine parts on my race car - unfortunately the number has worn off the label - it was intended as a fluid sealant but also stopped things working loose from vibration and it was weaker than most of the the others. Great for ally.
    Custodian of:-
    brd812's Avatar
    brd812 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Roaming Shores, Ohio, United States
    238
    Both the blues are about the same.... no major issue with either. clear nail polish on my piks on sled worked better than the blue locker. once the polish dries its water tight.
    "If you are going to piss like puppy, Don't Get Off The Porch"
    Trikes:
    84' Suzuki ALT185 (old Orange)
    85' Yamaha 225DX, piped and spaced ( First Girlfriend)
    Quads
    87' Yamaha Banshee, built and very very fast (The Whore)
    01 Yamaha Raptor 660, built and piped (The Beast)
    03 Suzuki Vinson, 26's and piped (The Crowd Pleaser)
    Once apon a time:
    85' Tecate 300 alky flattacker, 6 in over swingarm, 88 Suzuki 500"Quadzilla"PIA , 91 Yamaha Warrior Built and Modded. (luved that Baby Tank)
    NEPA
    7,051
    Nail polish is good. Dollar store super glue cured 24 hours is best What's wrong Kahuna,,didn't you like that tilt spring and retainer : )
