Results 1 to 8 of 8
Thread: 350x carb mod on 250sx
    Lewiston, N.Y.
    1,479
    Is any miss required or is this bolt and go? Any real advantage to this seeing as the sx is not really a sport trike? I have a fresh top end with a Rocky brand dome piston and a full supertrapp, for what its worth
    Yes, in your case it will allow more air and more gas (jetted up).
    You lose the cable mounted choke and the stock 350X choke has to be bent/ground to work but you will have gains over the stock carb.
    Lewiston, N.Y.
    1,479
    Just getting up to speed quicker ? Or do I gain 3 power bands?
    Quote Originally Posted by userj8670 View Post
    "3 power bands" My god, this is why I usually don't answer these questions..... I hope you were kidding.
    It will rev faster and get places quicker. The power, is adjustable by the amount of discs in your Supertrapp. You can get more low end or top end, but the SX is not a fast machine unless it's in the back of a truck.
    Your question was, is the carb an upgrade, and in your case it is.......
    murfman is offline Just Too Addicted Arm chair racerJust too addicted
    midwest
    467
    After rebuilding both my 350x and 250sx carbs it looks like the cable operated choke can be adapted to the 350 carb, but I did not look too closely.
    Lewiston, N.Y.
    1,479
    Yes it was meant as a joke
    May 2011
    eden,ny
    3,481
    I hope it was ! with that setup you could easily exspect 4 or 5 powerbands and maybe more! lol
    Michigan UP
    1,005
    For more power you could take out the power band and put in a super strong rubber band. Lol
