Results 1 to 8 of 8
Thread: Is there a high compression piston avaiable for ATC 200M?
    Wisconsin
    201
    Helping out a friend and he would like to get a little more power out of his trike. Is there a piston out there that will give it a 10:1 compression ratio? It would be a relativity cheap and quick solution.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    6,793
    Wisconsin
    201
    Solution?
    I found this one on ebay:
    http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
    Thats too high of a compression however if you take 3 metal shim head gaskets and seal coat them it should lower the ratio so you can run 93 octane in it then. Comments?
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Scootertrash's Avatar
    In the sticks
    4,638
    10.25:1
    Wiseco website list price: 163.39
    http://www.wiseco.com/ProductDetail....85&AppID=25398
    Ebay:Wiseco brand new- 69.95: http://www.ebay.com/itm/Wiseco-Pisto...sories&vxp=mtr
    louisiana
    1,499
    ebay has the best prices.
    Signature pic removed,becuase of no helmet.
    Lauderdale County, Alabama
    2,029
    The 10.25:1 is what I have in my 200S, it makes a huge difference, and I can still run plain gas. The piston in my bike is also a Wiseco 10:1.
    Dec 2007
    Quebec,Canada
    1,014
    wiseco hi compression 200x piston will fit
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    i have 10:25 pistons for 200x's $55 shipped new h&s piston kits
