Thread: 250sx question
    Jan 2011
    mifflinburg
    525
    250sx question
    Just wondering if anyone could tell me why I can just click my shifter down to hit reverse..
    Usually u would need to use the reverse button. Like push the button in and pull in lever and shift down for reverse.. All i need to do it, click it down... Cant figure this out....
    Feb 2006
    EC
    1,607
    There's a lever below your perch that the Rev button slides down into Wehn pushed, locks botton lever to the top lever. It's prob'ly stuck, look under your perch & you'll see it.
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    If they part under the reverse button on your brake lever is stuck that could cause it
    Jan 2011
    mifflinburg
    525
    Yep sure is stuck... Im going to try to Loosen the nut Wire brush it off a little and stick it back on, Maybe that will help. Thanks Guys!!
    Sarnia, Ontario, Canada
    3,415
    Also check the smaller of the 2 cables that run from the perch to the engine..this is what pulls on the reverse safety lock in the transmission.
    If the cable is siezed/sticking the spring pressure won't be enough to get it too return..holding the inter-lock to allow a reverse engagement.
    It's just a matter of time before an accidental down shift causes an abrupt bang!! Hope you don't have any loose fillings in your teeth..they will be coming out!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
