Thread: 200m and 200s ?
    Oct 2007
    new york
    811
    200m and 200s ?
    local guy has an 84 200s and is looking for a set of forks. i have a set off an 84 200M just wondering if they will fit and work .
    West by God Virginia
    45
    Yep i've switched forks between the M,S and E all the same as far as i can tell
    Sarnia, Ontario, Canada
    3,415
    185 also I believe!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Tionesta, PA
    5,747
    Quote Originally Posted by John-Boy View Post
    Nope - the E is different. - they are build as one with the triples. 200 M S and (1983)185S are all the same.
    45
    I should have seen that on others, All my Honda's are mutts with the same style forks (My 200 BR even had solid forks on it when i got it)
    Mar 2007
    Texas
    5,045
    Spot on sir! also the otehrs will NOT bolt up correctly to the E. I tried it, the neck angle of the E is also different causing the forks not to fit correctony on the others. I ended up doing special surgery on my 200e to get better forks. i pout 250sx fronts on my 200e and was the best thing i ever did!
    ________________
    https://www.mikesatvfix.com
