What weight oil does a ytm200 take i've misplaced my manual and don't what to put the wrong kind in.
Thanks
Thanks
I have no idea where my manual is either, but you can't go wrong with conventional 10W40 or 15W40 in that motor.
Thanks, change the oil and a few other little things and i should be able to finally be able to take it out and see how it rides
I found my service manual. It says you can use SAE 10W30, 10W40, 20W40 or Yamalube 4 cycle oil. Sounds like you get to pick the flavor you like best.
Thanks again I think i have some oil in the shed that will work, Hope i can just clean the filter as i have have no luck at my local dealer (Has to order every thing i've asked about)
