What are the advantages and disadvantages to the long rod on the Z?
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
Read this. It should help explain.
http://www.stahlheaders.com/Lit_Rod%20Length.htm
In addition to changes in rod angularity and piston dwell time, rod length can also affect crankcase volume. Case volume is added if a spacer plate is used.
2-stroke lover
True, I think the link I sent was directed towards 4 strokes. I'm not sure how the volume effects that engine. The few things I've read about 2 stroke case volume seems to indicate that less is better on most engines if the quest is for top end.
