Results 1 to 15 of 20
Thread: Will a Moto 4 350 Motor Bolt Directly on 1983 225 Dx
    Oct 2011
    Duluth
    5
    I was just wondering if anyone had any idea or information in regards to a Moto 4 motor bolting up to a 225 dx frame. if anyone has any answers i would greatly appreciate it. Thank You!
    louisiana
    1,499
    i was thinking about this myself.
    Signature pic removed,becuase of no helmet.
    glendive, montana
    1,822
    my neighbor has a moto 4 and I don't think he'll mind if I look over his motor mounts and measure it to check, it would be nice to slap a bigger four stroke in a yammi
    Pekin IL
    529
    Not sure about a moto 4 but we did try a 87 warrior 350 motor in a dx frame and there was no way. The motor is huge next to the 225. Alot wider and longer.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    May 2003
    Houston, Texas
    2,409
    Darn....that stinks
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Quote Originally Posted by hippyplz View Post
    You're talking apples and oranges there dude. The 225 is shaft drive, the Warrior is chain.
    Oct 2011
    Duluth
    5
    That would be great! I was looking online just compairing images and the moto 4 case bolt pattern looks very close to the 225 but as for being a bigger motor the spacing could be larger, but if you could get the measurements that would really help thanks.
    Pekin IL
    529
    Huh no kiding. Chain and shaft you say? crazy! From what I understand the moto4 and the warrior motors share alot of the same motor parts but you are right the warrior is chain. We did find that the stock size timberwolf 250 cylinder is the same size as the max bore dx piston. Could use the hole timberwolf top end but has a lower cr than the dx and dont think it would really be a performane gain.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Oct 2011
    Duluth
    5
    Yes the stock size timber wolf 250 is the max bore for the 225. But the 1992-2000 YFB250 Timberwolf 2x4 or 4x4, 1989-1991 YFM250 Moto 4, or the 1999-2004 YFM250X Beartracker all have the same jug. The bore on this jug STD is bore 71mm and stroke of 58mm. The max bore of the timberwolf is 72.00mm. As the STD bore of a 225 dx is 70mm and stroke of 58mm. So as you can see they would most likely bolt up to one another but the case of the 225 dx case would have to be bored to fit the larger piston diameter.
    How did we get from 350's to 250's? The 250 jug is such a small gain it isn't even worth it.
    Oct 2011
    Duluth
    5
    Ha your guess is as good as mine lol. As you can see i already did my homework on that and thats why i made this is to try and put a 350 in and not a 250.
    Dec 2010
    Pennsylvania
    510
    so the final is that the 350 wont fit?
    Nov 2007
    ulysses pa
    1,231
    there are alot of variables here. not just motor mount bolt pattern, out put and driveshaft connection, engine height, width, intake track, exhaust outlet, and so on and so on. i for one would love to see this happen but i dont think it can.
    OHIO
    2,857
    lol............just buy a Honda big red...it'll probably yank a 350 moto 4 backward anyway..huh Fabio Sorry, I could'nt help it.
    ontario
    1,131
    [QUOTE][lol............just buy a Honda big red...it'll probably yank a 350 moto 4 backward anyway..huh Fabio Sorry, I could'nt help it./QUOTE] this is very true my grand father would alway have to come and pull me and the moto4 out with his bigred. ahaha
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
