1st you need to remove the video link from your post..videos posted on the site must show people riding with proper safety equipment(helmet)!!
You can check for an electrical draw with a voltage meter..but it may just be that your battery is toast.
Take the battery out of the trike, charge it then allow it to sit for 12 hours disconnected..then use the voltage meter to measure the base voltage of your battery. Should hold at least 12.5 volts after it has had a chance to sit and let the surface charge to settle..it is drops into the 11 volt range replace it.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
