You know, there's tales of old pirates using piss mixed with olive oil in their rigs. Make sure it's EXTRA VIRGIN olive oil though, you don't want to put skanky oil in your machines, it might give them some kind of drive shaft disease, or chain warts.
............Arg.
They all have AGI or CLI or whatever certifications. Which means even Wally World cheapo oil is fine, just change it often. If it has that certification, your good.
If you run a stroked motor and with a cam (lots of $$$$$$), then I recommend some oil with some zinc in it like VR1 (Thank you Swigin) or there is another oil that has zinc in it, I forget the name at this time...
I'll go 2 hard rides or 20 easy cruises between oil changes but that is just what seems to work for me...............
edit - I think it's Shell/Rotella thats good too, I forget.
One more question ho do you know how much oil to put in because I have all the manuals and it never says how much.
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
Put 1/4 of a quart in and check the dipstick. Add in a bit more and check again. Repeat until there is enough oil to coat the bottom of the dipstick.
LED obsessed
2015 Yamaha FJ-09
Has anyone tried those stainless steel oil filters for the 350X yet? If so, how do you like'm?
http://www.cheapcycleparts.com/produ...eel-oil-filter
How do I know how much to put in the 1984 bigred 200? it dont say in the owners manual.
FILL IT TILL THE DIPSTICK SHOWS IT IS FULL!!!!!!!!!!!!
Thats what it is there for.
My God have you been smoking K2 with your son?
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
Make sure your oil is for motorcycles. The motorcycle oil is federally allowed to have more PTFEs, slippery components, than car oil. Clean your oil screen or make sure your oil filter is changed. And I'm a firm believer of fresh cheap correct oil beats old, worn out, expensive oil any day. Alot of people like synthetics. Alot of older clutches are not big fans of synthetic oils. Modern day clutches are much more forgiving to synthetics. Synthetics can be too slippery! LOL The limiting factors to most oils aren't the oils, themselves, but the filters. If modern oil filters get too clogged, they will bypass the filter media - BAD!
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
I have new screen and I would just like to know the honda manual oil info. is says to check it without screwing it in. the dip stick that is.
Okay.... its 1.8 litres..... use the dipstick sallie!
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
