Results 1 to 8 of 8
Thread: 350x engine cuts off on decel at high speed?
    3wheely's Avatar
    3wheely is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Florida
    259
    So when hitting fifth gear wide open (haven't tried 6th) and pulling in the clutch and hitting the brakes the engine cuts off. A little hard to start afterwards. Doesn't seem to do this in lower gears. Where should I start looking for a diagnosis? The exhaust pops on decel which may be a leak. Also when revving after idle there is a little smoke (greyish color). Uni filter/supertrapp pipe. Here's a pic of the plug. Any suggestions would be appreciated. Thanks guys. Attachment 0Click image for larger version.
    3wheely's Avatar
    Florida
    259
    Guess nobodies ever had this problem or has any ideas. Guess I'll get to work and try and figure this thing out.
    Camano Island, WA
    361
    Mine did that before.
    It was just a plug for me, i put a new one in and it worked great. Try a new plug first.
    ct
    1,396
    Sounds like and looks like you are running way too lean. Try going up 2 sizes on the main jet. Test her out. See if it eets better. If not, go up 2 more sizes. Keep going up until she bogs and then go back to the largest jet you had in before she stumbled. Should do the trick.
    Your lean, even more so if the air box lid is off...........
    3wheely's Avatar
    Florida
    259
    That's what I was thinking. Airbox lid was on. No mods other than the supertrapp and uni filter. I haven't counted the disks but I was going to take a few off to see if it richens it up enough but the bolts are seized. I think I'll put the stock pipe back on for now and see if that helps any. If not, on to jetting. Thanks for the help guys.
    Camano Island, WA
    361
    Oh yeah...thats probably why i burned up a plug or 2, because i didnt rejet after getting a new pipe.
    Now im running stock pilot, needle clip, but a 148 main.
    We will see how she goes!
    I havent got a chance to really open her up yet. Need to go riding!
    3wheely's Avatar
    Florida
    259
    Let me know how that 148 works for you. I've got to order a few this week. My 200x didn't need jetting after adding a pipe. But then again every bike is different.
