Results 1 to 11 of 11
Thread: Tri-z exhaust questions
    Toledo_Tommy's Avatar
    Toledo_Tommy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Toledo
    279
    Simple question : Is this a stock pipe for a 85 tri-z ? I didn't know if all stock pipes came with bolt on heat shields.
    Thanks for your input.
    May 2008
    Tenn
    548
    Not stock, from the way it looks in the pic.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    bigredridr's Avatar
    bigredridr is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    shoharie NY
    273
    looks aftermarket dg maybe. my stock pipe sits higher and has a "dent" to go around the lower corner of the radiator
    85 1/2 Tri-Z
    85 350X
    85 250ES
    MOTOMAX27's Avatar
    MOTOMAX27 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    Miami, FL
    266
    yep looks like a dg. maybe phase 5?? they look a like.
    bigredridr's Avatar
    Mar 2011
    shoharie NY
    273
    http://www.3wheelerworld.com/showthread.php/132835-Tri-Z-Pipe-Official-ID-Thread?highlight=triz+pipe[/URL]35-Tri-Z-Pipe-Official-ID-Thread?highlight=triz+pipe
    not sure how to do the link deal.
    85 1/2 Tri-Z
    85 350X
    85 250ES
    Tucson
    1,652
    Looks like a old school DG too me!
    Nov 2010
    Toledo
    279
    Yea, I can not find any stamping on it at all but thanks for the input. The Gasket seems to be leaking exhaust , how hard is it to find a new seal/flange/gasket for these ?
    May 2008
    Tenn
    548
    I've got a post somewhere on the board with the part number that you can use at your local parts house. The gasket with the metal insert and soft outside is the better one. If you can't find the post I'll try to look for it in the shop. On some aftermarket pipes it may take a little silicon also.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    MOTOMAX27's Avatar
    Oct 2006
    Miami, FL
    266
    clean it very good. use rvt gasket making. let it dry for 24hr then add more let it get tacky and push it in. works the best.
    Sep 2003
    Brookville,PA
    1,408
    My Tri-Z has an Answer pipe and silencer on it and it looks alot like yours.
    Nov 2010
    Toledo
    279
    Honestly I was thinking answer just because the silencer looks like a old answer silencer i had my wr500 2 stroke.
