Thread: Big Red recoil rebuild
    Sep 2011
    Macedon,NY
    17
    does anyone have advice in putting the spring back in this recoil, i have been trying for days and it just wont work. any help i can get will be appreciated
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    156
    The spring or the string ? Either way it has to come apart, If your talking about the spring it must be apart already though , With the center piece out ya can just wind it back into the case. Hook the end onto the lip and wind it inside itself.
    Jul 2011
    Lawrenceville PA
    6
    Your Not alone Fighting with that lil Bastar*
    The easyiest way I found was to TRY to Wind it as tight as you can in your hand (Gloves on) the Slip the End the Fits into the Housing in the notch While the other end is in the Inner Part as well (you have to Keep them Close to do this-Then Push it down (at first it wont seat properly) but as you start to Wind it up it will eventually) it took me about an Hour to Finally get it-Good Luck!
    Sep 2011
    Macedon,NY
    17
    i do have it apart and i am talking about putting the spring back in, i will have to try the gloves because the little tab on the inside of the spring cut me pretty deep the other day
