Results 1 to 2 of 2
Thread: 185s Piston Choices
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    185s Piston Choices
    Soon I will be ready to have the cylinder on my 185s bored and a new piston fitted. It has a 200 cylinder on it already and bored to 65.50 with a 10.25 compression piston but has piston slap and is starting to burn oil(previous owner had it bored wrong or put in wrong piston)
    I was gonna have the cylinder measured and see if a 66.00 piston will work. I can't decide if I want the Weisco 10.25:1 or 12:1 piston. Anybody know the actual compression ratio of the pistons in the engine?
    I figure the pistons don't have as high compression ratio as they say they do but I may be wrong. I don't mind running 93 octane but don't want to have to use race gas. Is there a thinner head gasket to bump the compression up a little more with the 10.25 piston?
    Thanks for any help.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Jul 2006
    western ny
    3,366
    id say stick with the 10.25:1 piston. ive had 12:1 and 10.25:1 im my 200s and the 10.25:1 was so much better. mine was bored 3mm (the max without resleeving the cylinder) and 12 was just too much for the head gasket to take. i went threw at least 3 head gaskets in 4 or 5 months. if your gunna bore it have it bored to the next size and go with the 10 rater than the 12 . the 12 also requires higher octain fuel as well.
    GIT IT RAAAGGGGG !!!!
