Results 1 to 7 of 7
Thread: 200x cr80 rear caliper swap
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    I have been looking for some info on putting the cr80-85 front caliper on my rear caliper on the 200x .
    i am a bit confused is it a bolt on swap ? or do i need the bracket from the 200x caliper ? (which i CAN NOT get off this piece of crap caliper i have now ) lol
    i am trying to save some money as i dont want to pay $100+ for a 200x caliper
    i already attempted to rebuild this one which was a waste of time and 25 bucks as it still leaks from the shaft where the parking break hits the piston .
    84 200s almost done
    84 atc 70 project
    Sep 2007
    100mi west of Chicago
    3,582
    You have to use the bracket from the 200x caliper, the CR85 bracket isn't quite right. Once you bolt that to the CR85 caliper, it will bolt right into place on the swinger.
    Here's the one I put on my 200x. I painted it black to look like the 200x oem caliper. Pay no attention to the missing brake line . You can pick these up on eBay for about the price of a 200x caliper rebuild kit all day long.
    Rob
    Feb 2009
    greentown PA
    389
    thanks for getting back to me . i cant get the old braket off i was afraid of that
    84 200s almost done
    84 atc 70 project
    NEPA
    7,051
    If your allen is stripped,,get the caliper in a GOOD vise. Peel the rubber back and use vice grips. That bracket will come right off that caliper..
    Feb 2009
    greentown PA
    389
    once that allens out the braket comes rigt off ? or is there another bolt somewhere ?
    84 200s almost done
    84 atc 70 project
    NEPA
    7,051
    It pivots on another pin,with no bolt whatsoever,,slides right off! Obviously,,they are corroded on there,,but they will come off.
    Jul 2008
    MD
    911
    I was in the same boat as you with on my old 200x. I used the cr85 bracket. I had to grind it down a little to fit, but it did work with a little work.
