Results 1 to 15 of 22
Thread: 250sx tires/rims and wheel spacers
    Lewiston, N.Y.
    1,477
    Whats everyone running these days for tires and rim and wheel spacers? I heard something about 400ex rims or something because they give the bike a wider stance? I have factory rims with these skinny little mudbogger POS's on there. They need to go. Please any pix would great
    Nov 2010
    Oshawa, On, Canada
    2,123
    I have 9" wheels with a 3 + 6 offset. Gives about an inch of extra width.. You could get a 2 + 7 and have it even wider...
    As for tires, if you want grip, bearclaws hands down... if you want a sporty look, that can slide... holeshots or razrs.... if you want your bike to look bad, get some knobbies.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Lewiston, N.Y.
    1,477
    What do you mean 3+6 or 2+7 offsets? Not sure i understand what that means.
    Nov 2010
    Oshawa, On, Canada
    2,123
    For example, mine are 9 " itp wheels, with a 3 + 6 offset. ( also referred to by 3:6 )
    The 3 in the offset means that from the contacting point against the hub, to the back, or inside of the wheels is 3 inches. (the edge of the wheel on the side facing your swinger) Smaller the number, the wider the stance.
    The 6 is from the point contacting the hub, to the outside lip of the wheel. ( the side you see when looking at the bike. )
    All these numbers change when you deal with narrower wheels. Like my bigreds, they are only 7 inches wide, so it is a 2 + 5 offset. ( which makes it really wide )
    When buying wheels, make sure you get a 9 inch, most aftermarket 8 inch will hit the brake drum..
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Sarnia, Ontario, Canada
    3,415
    I set mine up with 22x12x8 Bear Claw on the rear on the stock steel rim..no need for rim change.
    Front was a little tricky because the 22x12x8 was too wide for the forks and there was no other choice in the 8" in Bear Claws
    So I ordered a 11x7 steel with with 2+5 offset..then spaced it out with 2 - 1" spacers to get the rim to centre properly. Then mounted a 23x8x11 Bear Claw up front..
    It's outstanding! The high speed handling is awesome, the rough terrain handling is way better because you're not fighting a big tire that always wants to fight the ruts in the trail..
    And it looks sexy as hell!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Lewiston, N.Y.
    1,477
    @dougspcs - them rear tires are huge! It does have a nice stance to it though! The front tire is fine, I have a kenda up front with a 200x front end on it
Name:	250sx (2) 10.24.11.JPG
ID:	133994Click image for larger version.
Name:	250sx 10.24.11.JPG
    3,415
    Quote Originally Posted by userj8670 View Post
    I had a pair of the Duro's you got on the rear now..they were OK, but not great.
    After putting the Bear Claws on my Big Red, I decided I had to find a way to set up my SX with the same.
    Amazing difference..and the off-camber tippy factor is much reduced!!
    Highly recommend them..
    I like the setup of your front..though about doing that but chose the cheaper route instead.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    If you make it wider and jump anything, you WILL bend that swinger. It is all bolted together and the last thing it needs is weight spread out further.
    Trail ride it, you'll be AOK........
    Lewiston, N.Y.
    1,477
    steve, the sx is just a trail rider and hunting trike. Im not an aggressive rider so I think jumps are not a factor for me. If i want to get crazy I have my 350x for that but im just talking a need for speed, not jumps.
    Oct 2007
    Minneapolis mn
    4,067
    The 400ex wheels do not fit over the drum unless you use 1.50" spacers... (got that mess in my garage currently)
    Lewiston, N.Y.
    1,477
    Thorpe, is there anyone that makes 1.5 spacers? Im relatively new to SX mods.
    Oct 2007
    Minneapolis mn
    4,067
    http://www.ebay.com/itm/Two-1-5-Whee...item58900713f1
    Been running them on my BR for a year or two now... Well made, and I am not too gentle with my BR...
    Stonewall's Avatar
    Stonewall is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Bryan, Texas
    405
    For tires and wheels, for some reason everyone on here seems to preach Kenda Bearclaws, but if you really want the best tires, get some Interco Vampire TSL's: http://www.intercotire.com/tires.php?id=29&g=3 IMHO, they are the best ATV tire ever made. I just bought a set for my Big Red. Just pick the size tire you want and get rims to match! I recommend ITP steels or Delta steels, they are affordable and good quality.
    Here are my Vampire TSL's, just waiting on my ITP steels to arrive!!:
    Size is 27x12-11, which is probably too big for a SX, but they come in all different sizes! (even stock size!)
    1974 Honda ATC 70
    1985 Honda ATC 250 ES Big Red
    1986 Honda ATC 250 ES Big Red
    2008 Honda Rancher 420
    1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
    2010 Chevy Silverado 1500 4x4 LT
    1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
    My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
    There is no Z in Diesel!!!
    Lewiston, N.Y.
    1,477
    Personally I was looking for more polished wheels than the steel because I just think the steel over time looks like crap lol. However Steelies def have durability. Can I order polished rims with a 2+5(??) offset and if so where? I figure if i run the 2+5 and 1.5 inch spacers I should be sitting pretty nice.
    Mar 2011
    St. Paul, MN
    74
    My friends and I all run 1.5" spacers on our BRs and luv how it gives it more balance (especially since we lifted ours a couple inches in the rear).
    I paid about $45 for mine on ebay, similar to what Thorpe linked.
    My wheelers:
    current:
    '86 Honda ATC Big Red 250es - disc brakes, lifted, spaced and 27" Super Swamper TSL / Vampire (1.22" lugs) all-around
    '86 Honda ATC 250sx - Mud Bugs (1.19" lugs) in the rear
    '85 Honda ATC 250sx - not currently running
    '85 Honda ATC Big Red 250es - runs
    previous:
    '85 Honda ATC 200s
