I would position myself in the rear, grab hold of the rack and remember to lift with your legs not your back! Good luck!
.....One can only hope you're talking about ATCs.......Chris
wow this whole time i was tripping like y cant i reply to som post, so i started reading on how too do so and just read u have to post at lest ten post and wait a two month period lol well i guess this will be my first post
well hello everyone.. and,, thankx for the heads up 3ww.. this site is awesome.. great work guys,and/or girls.. happy trails from Ohio...![]()
Hello, New guy here from AZ, I need help with a honda 185s decompression cable, I do not know how to or where to connect it back inside the coil starter housing. Any help would be greatly appreciated.
Reverse Trike fan here from MN!
Three wheelers are cool, but I had a go-kart and a mini-trike that were 2F1R like the Spyder, I never had stability problems (unlike Dirt Wheels)...Did they know how to ride?
I want to build a Quad based Reverse trike! (Very easy to make it Street Legal!)
Like someone here is already building.
ive been on here just over 2 months and have just over 10 posts and stil lcant post on anything else. any ideas
Hey guys looking for some info on what color is the headlight guard supposed to be on a 1986 350x?
it is what it is.. 2 months is cool by me.. i hate spam and jerkoff people that scam on others... thanks for making a cool, useful site..![]()
I am having carb issues. I have a newer stock type carb,(has the weird bellows on top?) but the slide keeps sticking? It has been cleaned, new fuel used and will still hang up. I was thinking about trying to use a stock carb from some of my ATC/TRX 250r junk. Has anyone tried this? If so what jets and needle settings. The ES is all stock, just a yard/trail work toy. Thanks, Rick![]()
Hello everyone,
1st post and a huge fan of the site and Honda trikes!!!!
I traded for a 350X with engine in the frame as you could say a "roller" but allot of parts, bolts and the brake systems that were stripped off to paint the bike came in a handy to carry 5 gallon bucket of mess.
My issue and reason for the post is the rear brake stay bracket and the two bolts that go threw the bracket are about a 1/2 inch of from center on the bolts when attempting to bolt it up.
I have the Honda shop manual, understand the 85-86 rear brake difference, bought a different caliper, and brake stay and still am off from being able to mount this.
Since the brake stay from the bucket and a different one I purchased are the same I am thinking that who ever rebuilt the rear axle may have, could have put a different rear axle bracket on? else it just does not fit and I would have to drill the brake stay bracket about a 1/2 a drill bit out, and i do not want to rig it since I am trying to make it a restored trail king.
I can take and post pics or email people to explain what the heck I am talking about but hope someone else has figured out this issue and can help me out.
email is Bullyinflorida@yahoo.com and I again can try to post or email pics or a video of what I am having an issue with
Thnx
any help for a 81 250r transmission problems?
my 81 250r isnt shifting. i believe is is a problem with the shifter drum.
I have a 1985 ATC 200X that had the motor rebuilt by a professional. There was a rattle that started at high RPM's and when I called the guy who rebuilt it, he said that it was probably the cam chain. I loosened the adjuster bolt on the left side of the motor just a bit (like my manual instructed me to) took it for a little ride, revved the engine a bit and it just locked up. The motor seems seized because I can't move the kick start lever at all. I was just wondering if anybody had an idea of what it could be or what to look for before I have to tear it apart or pay for it to be done again. Any thoughts, suggestions or ideas would be greatly appreciated.
wetsand the slide with 1000 gritt in direction of travel lightly then wipe down with machine oil and dab machine oil on cable in such a way that it runs down into the casing of the cable incase the cable is sticking n work everything back and forth repeatedly to free it all up, or are you talking about the plastic slide? thats vac regulated you may have a leak in the pre vac bellows if i\\the slide is sticking sticking open. also wetsand that slide and lube with machine oil inside carb and on slide. thats how i get em working again... ive got a 250es clone with exact carb. im planning a future old 80s 250 sto stroke mikuni 56mm conversion
